2 min read
Improved UX for branching and filters
Published Aug 20, 2025 Updated Jan 27, 2026
Priyanka Koundal
Product Manager
Priyanka Koundal
We’ve introduced a redesigned rule editor for filters and branching in Flow Builder, focused on improving readability and control when configuring logic.
The updated interface supports both simple and nested conditions with precise operator handling, reusable actions, and a consistent experience across rule types, with no scripting required.
Filters and branching demo
See what’s new in the rule editor, including easier logic grouping with AND/OR/NOT, searchable operands, drag-and-drop reordering, and a unified experience across filters and branches.
A cleaner, more visual layout for logic
The rule editor has been restructured for readability. With collapsible branches and nested condition groups, it’s easier than ever to navigate even complex logic structures.
Define logic with AND, OR, and NOT
You can now define rule logic using AND, OR, and NOT operators—each with clear visual labels and structured condition blocks. Expand or collapse groups as needed to focus only on what matters.
Search, customize, and edit operands
Fields are searchable, operators are automatically scoped by datatype, and you can add custom values directly, so missing mock data doesn’t block rule setup.
Clone, clear, and reconfigure without starting over
You can clone individual rules or clear condition sets without deleting the entire block. This gives you more control and faster ways to adjust your logic without rewriting it.
Drag, drop, and reorder rules and groups
Rules and groups are now fully movable via drag-and-drop, making it easy to restructure your logic visually and quickly.
Delete conditions or entire branches
Delete individual conditions or entire branching blocks while choosing which branch to retain as the primary path, so your downstream flow steps remain intact.
Consistent across filters and branches
The new rule editor works the same way in both filter and branching contexts. Whether you’re configuring input/output filters or conditional branches, you’ll get a unified, predictable experience.
Redesigned for clarity and control
The new rule editor removes unnecessary complexity, making it faster to define and manage logic across your flows without relying on scripts.
Integration insights
