8 min read
Concurrency best practices for large data volumes
Published Feb 6, 2025 Updated Feb 13, 2026
Laurie Smith
Laurie Smith
In an iPaaS, concurrency is the platform’s ability to execute multiple tasks, processes, or workflows simultaneously. This enables integrations to run in parallel, efficiently managing overlapping operations such as concurrent API calls and large data transfers. By dividing workloads into smaller, parallel units, concurrency enhances performance, speeds up processing, and optimizes resource utilization.
Think of concurrency like a highway system. Without it, data moves along a single-lane road, forcing each task to wait for the one ahead, leading to slowdowns and bottlenecks. With concurrency, the system expands into a multi-lane highway, allowing multiple processes to run simultaneously, reducing congestion and improving speed. Just as traffic signals optimize vehicle flow, concurrency ensures efficient resource allocation, keeping integrations running smoothly without unnecessary delays.
Managing concurrency is critical for high-volume data processing. The right configuration speeds up data synchronization, prevents API throttling, and ensures consistent performance. Poorly managed concurrency, on the other hand, leads to delays, resource limits, and missed SLAs.
Here, we’ll explore how Celigo’s tools help you configure, monitor, and scale concurrency settings to keep your integrations fast, efficient, and reliable—even under heavy workloads.
Key benefits of concurrency management
  1. Enhanced performance and speed
    Processing tasks in parallel significantly reduces workflow completion times.
    • Example: Syncing 10,000 records with concurrency set to five threads can be five times faster than processing one record at a time.
  2. Improved scalability
    Concurrency ensures systems can handle growing data volumes without performance degradation, adapting to the demands of scaling businesses.
  3. Reduced latency for time-sensitive workflows
    Processes like inventory synchronization or payment processing benefit from concurrency by minimizing delays and meeting real-time requirements.
  4. Optimized resource utilization
    Concurrency ensures efficient use of system resources, minimizing idle time and maximizing throughput.
  5. Support for complex workflows
    Concurrent processing enables businesses to handle interdependent tasks, such as syncing parent and child records, without bottlenecks.
  6. Compliance with API governance
    Configuring concurrency appropriately helps avoid exceeding API rate limits, prevent throttling errors, and maintain consistent system performance.
    Examples of concurrency in an iPaaS
    • Ecommerce order processing
      Concurrency allows multiple customer orders to be processed simultaneously, syncing with an ERP system in parallel. This prevents bottlenecks and ensures timely order fulfillment, even during peak sales periods.
    • Real-time inventory updates
      Concurrency enables parallel API calls across multiple platforms (ERP, marketplaces, and warehouse management systems), significantly reducing the time required to update stock levels in real-time and preventing overselling and discrepancies.
    • Employee onboarding automation
      When a new employee is hired, concurrency allows multiple onboarding tasks (such as account creation, payroll setup, and software access provisioning) to be processed simultaneously across different systems, accelerating the onboarding experience and reducing manual delays.
    Core principles of concurrency in iPaaS
    • Parallel process execution
      Execute multiple workflows or tasks simultaneously while efficiently managing resources to prevent contention and performance degradation.
    • Dynamic workload scaling
      Automatically scale workloads up or down in response to demand, leveraging cloud-based architectures to optimize resource allocation for concurrent processes.
    • Error management and resilience
      Isolate and handle errors within concurrent processes independently, preventing failures from cascading and ensuring uninterrupted workflow execution.
    • Throughput and latency optimization
      Maximize data throughput while minimizing latency to maintain high-speed, efficient processing, even under heavy concurrent workloads.
    Best practices for managing large data volumes
    Optimize flow design
    • Partition data intelligently: Break down large datasets into logical segments (e.g., geographic regions, product categories) to enable parallel processing and reduce load on individual API calls.
    • Use prebuilt templates: Leverage Celigo’s preconfigured templates to streamline integration setup for common use cases.
    • Example: Partitioning order data by region (e.g., North America, EMEA, APAC) helps distribute processing load, reduces API throttling risks, and improves overall runtime efficiency.
    Configure concurrency settings effectively
    Tailor concurrency settings to align with system capacity and API rate limits to optimize performance.
    Steps to configure:
    1. Review API rate limits and thresholds: Check API documentation for rate limits, batch processing capabilities, and recommended concurrency settings.
    2. Set connection concurrency: Configure concurrency levels to match the API’s processing capacity without exceeding limits.
    3. Validate in a sandbox:  Test configurations in a non-production environment to prevent disruptions in live operations.
    Enable delta data processing
    Delta processing improves efficiency by syncing only modified or newly created records, reducing API usage and processing time.
    How to configure:
    1. Create a filter:  Define conditions to extract only records updated since the last successful sync.
    2. Activate delta processing:  Enable delta settings in the flow configuration to track and process incremental changes.
    3. Validate results:  Compare synced records against source logs to confirm accuracy.
    Monitor and scale dynamically
    • Use Celigo’s monitoring tools to track key performance metrics such as execution time, error rates, and throughput.
    • Scale runtime resources dynamically based on data volume fluctuations, ensuring smooth operations during peak loads.
    Leverage parallel flows
    • Running datasets through multiple concurrent flows reduces runtime while maintaining system stability.
      • Example: Instead of processing all inventory data in a single flow, split it by product categories (e.g., electronics, apparel) to prevent bottlenecks and improve processing speed.
    Celigo’s approach to concurrency
    Celigo provides powerful tools to configure, monitor, and scale workflows, delivering reliable performance even under high-volume demands.
    Key features include:
    Dynamic paging and parallel processing
    • What it does: Divides large datasets into smaller, manageable chunks for parallel execution, reducing processing time and system strain.
    • Benefits: Optimizes API efficiency, minimizes load on target systems, and improves data throughput.
    • Example: Adjusting Salesforce SOQL query page sizes to 200–1000 records balances performance while preventing timeouts and API rate limit violations.
    AI-powered optimizations
    • Predictive monitoring: AI continuously analyzes historical and real-time data to detect anomalies and suggest proactive adjustments, preventing issues like API throttling.
      • Example: If API usage nears rate limits, Celigo recommends reducing thread counts or increasing throttle delays to maintain smooth processing.
    • Dynamic scaling insights: AI optimizes key settings such as page sizes, thread counts, and throttle delays based on actual workload patterns, ensuring workflows automatically adapt to peak loads.
    Built-in exception management
    • Automated retries: Resolves transient errors  (e.g., timeouts, temporary API outages) without manual intervention.
      • Example: A network outage triggers automatic retries, preventing workflow disruptions.
    • Detailed error logs: Captures persistent issues (e.g., invalid credentials, permission errors) for manual review.
    • Tagging and assignment: Classifies exceptions by type and assigns them to the appropriate team members for faster resolution.
    Connection-level concurrency controls
    • What it does: Configures concurrent API requests to maximize throughput while preventing throttling.
    • Example: If an API has a 60-requests-per-minute limit, Celigo can limit concurrency to 5 requests with a 1-second throttle delay, ensuring efficient and compliant execution.
    Preserving record order
    For workflows requiring sequential data processing, Celigo’s Preserve Record Order feature ensures data integrity, making it ideal for:
    • Financial transactions (e.g., invoice processing)
    • Parent-child relationships (e.g., hierarchical customer or product data)
    Elastic scalability
    • What it does: Celigo’s cloud-native infrastructure dynamically scales to handle workload spikes, ensuring consistent performance without manual intervention.
    • Powered by:
      • Amazon SQS – Efficient message queuing for parallel processing
      • Amazon S3 – Secure and scalable storage for large datasets
      • MongoDB – High-performance data persistence for fast retrieval
    Recommended concurrency settings for common scenarios
    Scenario Recommended Settings Notes
    APIs with strict rate limits Concurrency: 5 requests
    Throttle Delay: 1 second
    Ensure the total number of requests does not exceed API rate limits.
    High-latency APIs Page Size: 50–100 records
    Concurrency: 2–3 threads
    Smaller page sizes reduce payload size and avoid timeouts caused by slow responses.
    Low-latency, high-capacity APIs Page Size: 1000+ records
    Concurrency: 5–10 threads
    Larger pages and higher concurrency leverage system capacity for faster data processing.
    Data requiring sequential processing Concurrency: 1 thread
    Enable Preserve Record Order
    Ensures data is processed in the correct order.
    Dynamic workloads Enable Dynamic Scaling
    Monitor using dashboards
    Adjust concurrency dynamically during peak loads based on real-time metrics.
    Error-prone APIs Enable Automated Retries
    Retry Delay: 1–5 seconds
    Configure retries to handle transient errors like timeouts or temporary unavailability.
    Customization may be required based on the specific API or workload, and regular monitoring is essential for maintaining optimal performance.
    Beyond performance tuning, proactive error management helps detect and address potential issues before they escalate. Automated alerts can notify teams of problems, such as exceeding API rate limits or connection failures due to high request volumes, allowing immediate action to prevent disruptions.
    Maximize throughput and keep data flowing
    Effective concurrency management is essential for optimizing large data volume processing in an iPaaS. By configuring parallel execution, leveraging AI-driven optimizations, and implementing robust exception handling, organizations can achieve higher throughput, reduced latency, and seamless scalability.
    By following these best practices, teams can ensure smooth, efficient, and resilient integrations—even under the most demanding data conditions.
    Additional concurrency resources
    Integration insights
