10 min read
System integration: Types, methods, and examples
Published Mar 24, 2026
Adam Peña
Adam Peña
As enterprises grow, disconnected systems create bottlenecks across finance, inventory, ecommerce, and customer operations. Data is trapped in silos, reporting is delayed, and teams rely on manual workarounds to reconcile information across platforms. System integration is a strategic necessity to enable real-time visibility, accurate reporting, and automated workflows that scale with the business.
System integration is no longer just a technical project. It is the foundation for enterprise application integration (EAI), data integration, and the creation of an integrated system that supports end-to-end processes. This article explores what system integration is, its types, key approaches, and practical steps to break down silos and overcome challenges in enterprise environments. It also highlights how integrated workflows unlock measurable business impact.
Critically, we are seeing a shift from point-to-point and enterprise service bus (ESB)-heavy architectures to API-led, event-driven, and iPaaS-based approaches. Modern systems integration strategies emphasize governance, reuse, and visibility to share data across systems, rather than bespoke automation scripts maintained by a single system integrator. This guide helps IT leaders evaluate where they are today and where their system integration architecture needs to evolve.
What is system integration?
At its core, system integration is the process of linking disparate subsystems to share data and work as a cohesive infrastructure. For enterprise architects and integration developers, system integration is the architectural discipline of connecting applications and data sources—each with clear roles as systems of record—so that, once integrated, they behave as a unified, composable enterprise.
In practice, this means enabling reliable shared data flows between platforms such as CRM, ERP, ecommerce, and HR systems. An integrated system ensures that when a customer record is updated in CRM, downstream workflows in ERP, billing, and fulfillment are automatically updated and aligned. System Integration allows organizations to automate processes that would otherwise require manual reconciliation.
Enterprise drivers for system integration include operational scale, regulatory compliance, faster time to market, and improved customer experience. As enterprises adopt more SaaS applications and cloud platforms, horizontal integration and API-based connectivity become essential. APIs allow subsystems to communicate in near real time, while system integration ensures consistent, trusted shared data across business units. This is where EAI plays a critical role: EAI provides the framework for coordinating application-level communication across subsystems in a governed way.
Clear systems of record are foundational. ERP may own financials and orders, CRM may own customer engagement, HRIS may own employee data, and ecommerce may own digital transactions. Even when integrated, subsystems maintain authority over their respective domains.
System integration does not blur these boundaries; it respects them while enabling the automation of shared data and unified reporting. This is central to composable enterprise architecture: integrations are what allow organizations to swap or add applications without breaking core workflows.
For example, a global manufacturer might integrate its ERP with a CRM and logistics platform to automate order-to-cash processes. A retailer might integrate ecommerce, payments, and warehouse systems to provide real-time inventory visibility. In each case, system integration creates a unified operating model for automation without collapsing distinct subsystems into a single monolith.
Ultimately, system integration is foundational to building an integrated system that supports both agility and governance at enterprise scale.
Types of system integration and how they work
System integration can take multiple architectural forms. The right approach depends on organizational scale, complexity, regulatory requirements, and long-term modernization goals. Below are common types of system integration seen in enterprise environments.
Vertical integration (Silo method)
Vertical integration connects subsystems within a specific functional stack, often centered around a core platform such as ERP. This can appear as ERP-centric architecture where finance, procurement, and manufacturing subsystems are tightly integrated with custom logic.
The vertical integration approach is often used at a departmental or line-of-business level. It can automate workflows quickly and create an integrated system within that domain.
Pros:
  • Faster implementation of a specific business area
  • Clear ownership within a single team
Cons:
  • Brittle long-term architecture
  • Difficult horizontal integration across other subsystems
  • Increased dependency on custom code or a specific system integrator
Vertical integrations often struggle when enterprises attempt broader EAI initiatives that span multiple subsystems and business domains.
Horizontal integration (Enterprise service bus)
Horizontal integration introduces a central communication layer, often an enterprise service bus. The ESB acts as middleware that routes, transforms, and orchestrates data flows between subsystems.
This model is common in legacy systems environments and large on-prem enterprises. Horizontal integration enables enterprise application integration at scale and can unify communications across diverse subsystems.
Pros:
  • Centralized control and governance over integrated data
  • Strong support for complex routing and transformations between subsystems
Cons:
  • ESB can become a bottleneck
  • Scaling and upgrading can be complex
  • Heavy operational overhead
In practice, many enterprises find that their enterprise service bus becomes a constraint as new cloud subsystems and APIs are introduced. Modernizing beyond ESB-heavy models is often necessary to keep subsystems aligned and adaptable.
Star integration (Spaghetti method)
Star integration, sometimes called the spaghetti method, relies on point-to-point APIs between subsystems. As SaaS adoption grows, teams often connect CRM to ERP, ERP to ecommerce, and marketing tools to CRM directly.
This is often seen in fast-growing companies: ad hoc APIs integrating everywhere, often built quickly to solve immediate needs.
Pros:
  • Quick to deploy
  • Minimal initial infrastructure
Cons:
  • Integration sprawl
  • Fragile dependencies
  • Limited visibility into data flows
Over time, these integration system connections become difficult to manage, especially when subsystems evolve independently.
Common data format integration
Common data format integration standardizes and normalizes data across systems. Rather than tightly coupling applications, enterprises define shared schemas to support data integration and analytics.
This type is often used for reporting, master data management, and cross-system workflows.
Pros:
  • Supports unified analytics and reporting
  • Reduces inconsistencies across systems
Cons:
  • Requires strong governance
  • Upfront investment in data modeling
System integrators frequently combine this approach with horizontal integrations to create a more unified enterprise architecture.
System integration methods and approaches
The previously listed types of system integration describe architectural models of integration strategy. Meanwhile, integration methods and approaches describe how data moves and how integrations are implemented, independent of the larger context of system integration.
Point-to-point integration
Point-to-point systems integration connects two systems directly, often using APIs. It is simple and can be effective for the automation of limited use cases, such as syncing CRM and ERP.
However, as the number of systems grows, so does complexity. Each new integration increases maintenance overhead and risk.
Hub-and-spoke integration
Hub-and-spoke models use a central hub to manage integrations. This may resemble an enterprise service bus or middleware layer that orchestrates workflows and manages data integration centrally.
This model can improve governance but may still inherit ESB limitations if not modernized.
EDI (Electronic Data Interchange)
EDI is widely used for structured document exchange between enterprises, particularly in supply chain and logistics contexts. Sharing data in this way remains critical for many ERP-driven processes and enterprise application integration scenarios involving partners.
EDI integrates well into broader integration strategies but often requires specialized mapping and monitoring.
iPaaS (Integration Platform as a Service)
iPaaS is a cloud-based integration platform that provides prebuilt connectors for common SaaS, ERP, and CRM applications. It includes low-code tools for building and orchestrating workflows, centralized monitoring and logging, and governance features such as access control and environment separation.
Modern iPaaS platforms support both API-led and event-driven integration, making them well-suited for SaaS-heavy and hybrid landscapes. Compared to traditional ESB and DIY point-to-point approaches, iPaaS is typically faster to implement, easier to govern, and better aligned with cloud architectures.
Celigo is an example of a modern iPaaS designed for complex, multi-application environments spanning SaaS and on-prem systems. Rather than replacing every subsystem, it helps enterprises build an integrated system with visibility and control across integrations.
System integration challenges
Enterprises face recurring challenges when executing system integration initiatives:
  • Legacy systems and technical debt that limit API support and constrain data flows
  • Data quality and mapping issues that undermine data integration efforts
  • Security, compliance, and governance concerns across integrated environments
  • Scalability and performance bottlenecks in horizontal integration models
  • Organizational ownership gaps between IT, business units, and external system integrators
  • Aging legacy systems that were not designed to integrate easily with cloud applications, increasing customization and maintenance overhead
  • Vendor sprawl and tool fragmentation across CRM, ERP, and marketing platforms
  • Observability and monitoring complexity across workflows
  • Change management in tightly integrated ecosystems
Integrations built ad hoc inside individual tools and custom scripts quickly lead to integration sprawl. Without centralized oversight, duplicated logic and inconsistent transformations proliferate across subsystems.
These challenges directly impact operational performance, reporting accuracy, and enterprise agility.
Best practices for successful enterprise system integration
Successful system integration requires a structured, maturity-based approach:
  • Define business objectives and success metrics aligned to operational outcomes
  • Assess existing systems and data flows across ERP, CRM, and other platforms
  • Choose integration architecture and tools based on scale, risk, and long-term flexibility for security, governance, and monitoring from the outset
  • Build incrementally using reusable API patterns and standardized workflows
  • Validate and iterate with clear feedback loops
  • Clarify systems of record and shared data models before you automate processes
  • Centralize integration and workflow orchestration on a platform to create a unified, governed integration layer
When selecting tools, enterprises should evaluate system integration capabilities in the context of risk, compliance, and future scale.
A modern iPaaS such as Celigo supports governance, reuse, and visibility across both SaaS and on-prem environments, helping system integrators and internal teams implement integration with confidence.
Deployment options for integrated systems
Integrated systems can be deployed in several ways:
  • On-premises: Suitable for highly regulated industries or legacy systems environments. Offers control but can limit scalability and API innovation.
  • Cloud: Enables scalable data integration, real-time data flows, and rapid deployment. Cloud-native integration can automate cross-application workflows efficiently.
  • Hybrid: Combines on-prem and cloud systems. Modern iPaaS platforms are typically cloud-native but connect to on-prem systems through secure agents, supporting hybrid system integration strategies.
  • Managed services and integration platforms: Enterprises may rely on a system integration specialist or managed provider, or adopt a centralized integration platform to oversee APIs and workflows.
Decision criteria should include multi-cloud requirements, data residency constraints, disaster recovery, resilience, and cost. Leaders should also assess how well each model supports unified governance and long-term enterprise modernization.
How Celigo simplifies system integration
Enterprises need a central integration backbone to reduce errors, accelerate reporting, and support complex cross-system rules. Without it, integrations multiply, data flows become opaque, and operational risk increases.
Celigo provides a modern iPaaS backbone that connects ERP, WMS, 3PL, payments, financial systems, CRM, and more into a cohesive integration system. It is not a system integrator; it is the integration platform that system integrators, IT teams, and business users build on.
Key differentiators include:
  • Prebuilt integration flows combined with extensibility
  • Centralized governance and monitoring
  • Support for real-time and batch data integration
  • AI-powered error handling and observability
  • Multi-channel and multi-region capabilities
By standardizing system integration on a unified platform, enterprises can move beyond ESB constraints and point-to-point sprawl. The result is a more resilient, scalable, and future-ready integration architecture.
To see how this approach works in practice, explore Celigo’s Integration Marketplace and evaluate how a modern iPaaS can support your enterprise system integration strategy.
