What is a multi-agent system? Definition, architecture, and how it works
Some enterprise problems cannot be solved by a single intelligent agent. Too many systems, too many domains, too many interdependencies. Some enterprise problems are better handled by multiple specialized agents than by a single agent coordinating every step itself.
Multi-agent systems (MAS) are the architectural answer to that class of problem.
A multi-agent system is a network of autonomous software or AI agents that collaborate, coordinate, or compete within a shared environment to accomplish goals that exceed the scope of any single agent. In modern enterprise AI deployments, those agents often use LLMs or other decision engines to reason and act across systems.
Emerging open protocols cover different parts of the coordination stack. MCP standardizes how AI applications access tools, data, and workflows, while A2A is designed for direct communication between agents. Together, they point toward a more interoperable agent ecosystem, but enterprises should still treat this standards landscape as evolving.
For enterprise architects and IT leaders, MAS is not primarily an AI feature. It is an architectural decision about how to structure autonomous, cross-system workflows at scale.
Multi-agent systems vs. single-agent systems
Agentic systems exist on a spectrum. At one end, structured agentic workflows follow a predefined sequence, effective for repeatable, well-understood tasks. A step up is the autonomous single agent: an independent entity that reasons, uses tools, and corrects its own mistakes within a bounded environment. At the far end are multi-agent systems, in which multiple specialized intelligent agents coordinate across a distributed environment to produce outcomes that no individual agent could achieve alone.
Single-agent systems suit well-defined, repeatable tasks where centralized control is sufficient. Fraud detection on a single data source. Recommendation logic within one platform. Document classification within a defined schema. They are simpler to design, easier to debug, and produce predictable results within their scope.
Multi-agent systems operate differently. Specialized agents model each other’s goals, share state or memory, and coordinate actions across a distributed environment. Each agent works within its domain. The system as a whole delivers outcomes that require parallel execution, domain specialization, or cross-system data flows spanning systems of record with different schemas, access models, and ownership rules.
Choosing between these approaches is not about sophistication. It is about matching architecture to problem complexity. A predetermined sequence handled by one agent or a structured workflow is faster and cheaper when that is sufficient. When a problem demands dynamic coordination across specialized domains and multiple systems of record, multi-agent architecture stops being a preference and becomes a design requirement.
How multi-agent systems work
At the operational level, every agent in a MAS runs through the same repeating cycle: perceive, reason, act, communicate.
Perception means reading data from connected systems, monitoring event streams, or receiving inputs from other agents. Reasoning follows, typically powered by a large language model (LLM) that evaluates the current state, formulates a plan, and selects the next action. Execution comes next: querying a system, updating a record, calling an API, generating output. The agent then communicates results to the rest of the network through structured message passing or shared state, and the cycle continues.
What separates a collection of agents from a coherent system is the orchestration layer. An orchestrator agent, or a predefined coordination graph, breaks complex tasks into discrete subtasks, routes each to the right specialized agent, manages sequencing and dependencies, and consolidates outputs. These coordination patterns can be hierarchical, with a centralized orchestrator delegating tasks to subordinate agents, or peer-to-peer, with agents coordinating directly.
Handoff patterns govern how one agent transfers context and control to the next, the same coordination logic underlying any well-structured agentic workflow. Routing logic determines agent assignment based on domain, capability, or current load.
The underlying point is that agents have no value in isolation. Their usefulness depends entirely on governed, event-driven interaction across the system. An agent that cannot reliably read from and write to the systems it is supposed to act on contributes nothing. It introduces coordination risk.
Core components of a multi-agent system
Three foundational elements determine whether a MAS can scale, govern, and coordinate reliably in an enterprise environment. Weaknesses at this layer do not produce isolated failures. They produce cascading ones.
Agents
Agents are the autonomous decision-making entities within the system. Each has a defined role, a set of capabilities and tools it can invoke, and an objective it is built to achieve. In enterprise deployments, agent design maps directly to domain ownership: which agent is responsible for which system of record, and under what conditions it can act on that system.
Four agent types cover the range of reasoning approaches used in practice. Goal-based agents plan sequences of actions toward a defined end state. Reflex agents respond to specific triggers without maintaining state. Utility-based agents optimize across competing outcomes.
Model-based agents maintain an internal representation of the world and update it continuously as they act. Production MAS deployments typically combine these types across the agent network, with the framework matching the reasoning model to the requirements of each domain.
Environment
The environment is the shared space where agents operate, perceive, and interact. In enterprise deployments, this is not abstract. It is the specific systems that agents connect to: CRM, ERP, support platforms, finance systems, logistics platforms, and the event streams and APIs that run between them. The environment provides resources, imposes constraints, and serves as the medium for indirect communication between agents.
One design principle that gets underweighted: the environment is not passive. When an agent changes a shared system, every other agent reading from that system sees the effect. That makes data integrity and system-of-record discipline foundational, not optional. An agent working from stale, conflicted, or unvalidated data does not just produce a bad decision. It propagates that error downstream to every agent reading from the same state.
Communication protocols
For agents to exchange information, negotiate tasks, and coordinate interactions, they need structured rules governing these processes. Without those rules, interactions become unpredictable, unauditable, and ungovernable at enterprise scale. Communication protocols belong in the governance category, not the implementation-detail category.
Current protocol standards cover the main coordination needs. Model Context Protocol (MCP) handles structured access to tools and contexts. Agent-to-Agent (A2A) covers direct inter-agent communication. Together they provide the interoperability layer that lets agents built on different frameworks coordinate reliably, and they make it possible to extend the agent network without rebuilding the communication architecture each time.
Enterprise use cases for multi-agent systems
MAS produce their highest value across interconnected enterprise systems, not within a single application. Each scenario below has a defined trigger, a coordination layer spanning multiple systems of record, and a measurable operational result.
Supply chain and logistics
A MAS deployment in the supply chain connects specialized agents across procurement, inventory management, and fulfillment. A demand forecasting agent monitors sales signals and consumption patterns in the ERP. An inventory agent tracks stock levels across warehouse management systems. A procurement agent watches supplier lead times and pricing in vendor management platforms.
When the forecasting agent detects a projected shortfall, it triggers the inventory agent to validate stock, which triggers the procurement agent to initiate a replenishment order, with no human manually coordinating any of those handoffs.
No single agent owns the supply chain workflow. The outcome requires agents sharing real-time data across systems and passing context through a governed coordination layer. When disruption hits, whether a supplier delay, a logistics failure, or an unexpected demand spike, agents adjust based on changed state and downstream agents follow. That kind of AI for process automation is not something static workflows can replicate.
Customer operations
A MAS in customer operations automates the full case lifecycle across support, CRM, and billing platforms. An intake agent handles initial triage, classifies the issue, and routes to the right specialist. A resolution agent pulls documentation from the knowledge base and order history from the ERP. An execution agent applies the fix, updating an entitlement, processing a refund, or adjusting a billing record, and a sync agent writes the outcome back to the CRM as the authoritative record.
The handoff architecture is explicit throughout. Each agent receives a structured context package from its predecessor, acts within its defined scope, and passes a structured output forward. The integration between support, CRM, and billing is what makes this possible. Without it, agents can surface customer data. They cannot act on it.
Financial operations
A MAS in financial operations coordinates across risk assessment, fraud detection, and portfolio management. A risk agent continuously evaluates exposure using data from the risk management platform. A fraud detection agent monitors transaction patterns in real time and flags anomalies. A compliance agent cross-references flagged transactions against regulatory requirements and routes cases requiring human review.
Data accuracy is not negotiable here. An agent working from stale risk data or unreconciled transaction records does not produce a conservative result. It produces an unreliable one. Whether multi-agent coordination enhances or undermines decision quality in this domain comes down entirely to the integrity of the integration layer connecting the underlying financial systems.
Advantages and challenges of multi-agent systems at scale
For enterprise architects evaluating MAS, the advantages and challenges are two sides of the same architectural decision. Separating a production-grade deployment from a proof of concept that never scales requires understanding both clearly.
Advantages
- Scalability through distributed execution: Workload spreads across specialized agents rather than concentrating in a single reasoning process. As the scope grows, agents can be added or expanded without redesigning the core architecture.
- Resilience through redundancy: When one agent fails or becomes unavailable, the rest of the system keeps running. Failures stay contained rather than becoming catastrophic, assuming the coordination layer handles them correctly.
- Domain specialization: Each agent is optimized for a specific system, task, or decision type. Specialized reasoning outperforms generalist reasoning across all domains simultaneously, and it maps cleanly to system-of-record ownership in enterprise environments.
- Context efficiency: Each agent receives only the context relevant to its specific subtask. Compared to a single monolithic agent carrying the full problem scope, this reduces token overhead, lightens reasoning load, and improves output quality within each domain.
- Parallel execution: Independent agents work across different domains simultaneously, compressing the elapsed time of workflows that would otherwise require sequential handoffs. In time-sensitive enterprise scenarios, order management, fraud detection, incident response, that compression translates directly to operational speed.
Challenges
- Coordination complexity: More agents and more systems mean a larger coordination surface, and scalability becomes a design concern rather than a given. Sequencing, dependency management, and context passing all become harder to reason about and more expensive to debug as the network grows.
- Emergent behavior: Decentralized agent networks interacting with shared state can produce outcomes that were not anticipated at design time. Tracing the chain of decisions that produced a given result requires an observability infrastructure built for that purpose.
- Computational cost: LLM inference costs accumulate at every reasoning step. A large agent network where each agent makes multiple LLM calls per workflow can become economically unviable if the architecture does not account for this from the start.
- Debugging non-deterministic workflows: Agentic workflows involving LLM reasoning do not produce the same output for the same input every time. Reproducing a failure means having full execution traces. That requires observability and logging baked into the architecture before a failure occurs, not retrofitted after one.
These are design and governance problems, not inherent limitations of the paradigm. They are solvable. Solving them requires treating the integration and orchestration layer as a first-class architectural concern from the beginning.
The challenges of operationalizing AI at enterprise scale are well-documented. MAS deployments without governed integration compound all of them.
Why integration is the foundation of multi-agent systems at scale
Without a governed integration layer, multi-agent systems cannot function reliably at enterprise scale. This is not a feature consideration. It is the architectural prerequisite that determines whether a MAS delivers value or accumulates technical debt.
Agents need real-time read and write access to systems of record. A customer operations agent that cannot reliably reach the CRM customer record produces guesses, not resolutions. A financial agent running on T+1 batch data in a real-time risk environment is not slow. It is wrong. When structured integration is absent, data flows break, system-of-record ownership becomes ambiguous, and coordination errors multiply across the pipeline.
Integration is the connective tissue that makes agent coordination work. It is what lets an orchestrator route tasks to the right agent with the right context. It is what allows an agentic workflow to fire on a real-time event, an order placed, a case opened, a risk threshold crossed, rather than waiting for a scheduled batch job. It is what ensures that when one agent writes a result back to a system of record, the next agent reads an accurate, current state.
Governance, error handling, and observability are not additions to a production MAS deployment. They are prerequisites. When a workflow spans five agents and four systems, a silent failure midway through does not surface as a visible error. It surfaces as a downstream agent acting on an incomplete context, producing a system of record in an inconsistent state and operational consequences that are difficult to trace and expensive to fix.
Catching failures before they cascade is the job of the integration layer, through error handling that routes problems to the right remediation path, observability that catches degraded flows before full failure, and governance that enforces data ownership rules across the entire agent network.
A MAS without governed integration creates coordination risk at the same rate it creates coordination capability.
Celigo: An intelligent automation platform for enterprise AI orchestration
Enterprise multi-agent systems need an intelligent automation platform that can reliably connect AI agents to the systems they need to act on at scale, with the governance needed to ensure production deployments are trustworthy.
Celigo provides that foundation. As an intelligent automation platform built for cross-system orchestration, Celigo connects agents to the systems of record that matter, CRM, ERP, support platforms, and finance systems, through governed, API-led integration that maintains data accuracy and system-of-record discipline across the full agent network.
Where Celigo fits in a MAS architecture:
- Integration-first foundation: Agents connect to systems of record through governed integration flows rather than ad hoc API calls. Data ownership is explicit, access is controlled, and every read and write is traceable.
- Cross-app orchestration: Celigo governs how data moves between agents and systems across the enterprise, coordinating the event-driven handoffs that multi-agent workflows depend on.
- Event-driven workflow triggers: Agentic workflows fire on real-time signals, a new order, an opened support case, a risk threshold breach, rather than polling or batch schedules.
- Governance and observability: Integration health is visible across the full system. Celigo surfaces degraded flows before they fail, providing the operational visibility that production MAS deployments require.
- Error handling and monitoring: When a coordination failure occurs, Celigo routes it to the appropriate remediation path, preventing a single-agent failure from cascading through the pipeline.
Celigo is not an AI model, an RPA tool, or a generic workflow builder. It is the intelligent automation platform that makes enterprise MAS architecturally sound, governing the integration, orchestration, and observability layer that determines whether an agentic architecture holds up in production or accumulates coordination debt at scale.
→Request a demo to see how Celigo’s intelligent automation platform supports enterprise multi-agent deployments.
