4 min read
Discover next-level integration: Explore what’s possible with Celigo
Published Sep 3, 2024
Celigo
Celigo
3 key takeaways
  • Celigo is going beyond the capabilities of traditional iPaaS systems.
  • New integration patterns allow your business to integrate more than ever before.
  • Now, you can integrate any and all business processes with Celigo.
The business landscape is evolving more rapidly than ever before, driven by the adoption of cutting-edge innovations like AI. Whether you work for a startup or an established enterprise, the pressure is on you to drive revenue, stay competitive, and meet stakeholder expectations.
But achieving those goals is easier said than done–especially when your processes are working against you. The culprit of these inefficiencies is often data silos.
Data silos prevent you from streamlining your processes, accessing your data, and implementing automation. To eliminate silos once and for all, you need integration–and a modern integration platform.
Celigo’s iPaaS (Integration Platform as a Service) goes beyond the capabilities of traditional iPaaS systems to help you integrate your entire tech stack and automate processes end-to-end. And, we aren’t stopping there. We’re taking our platform to the next level, so you can propel your business to even greater success.
See how Celigo can empower your business to break boundaries and achieve more.
A platform for IT all users
Celigo’s iPaaS makes integration easier for everyone on your team, no matter their technical skill level. With our intuitive interface and AI features, you can democratize integration and empower all your teams to automate processes.
AI acts as a translator to help non-technical users better understand the integration process and what their automations and configurations mean. Chat-enabled editors support natural language and offer auto-documentation that allows business users to see exactly how each flow works.
On top of that, the Celigo AI Knowledge Bot provides your teams with contextual support and information summaries that link to knowledge base articles. With key information at their fingertips, both technical and non-technical users can build integrations more efficiently.
Celigo is also streamlining error management. Our AI-powered error classifier automatically resolves 95% of errors. This significantly reduces the time your teams spend identifying and fixing errors.
Solving application integration multiple integration patterns
We’re taking our iPaaS platform beyond application integration. With brand new integration patterns launching, you can now automate any and all of your business processes.
Our latest integration pattern, Celigo B2B manager, is making it easier than ever to work with trading partners. With this new solution, you’ll get a unified integration platform to manage EDI and B2B integrations, streamlined trading partner integration, enhanced visibility and control, and more.
Celigo B2B manager helps you build integrations quicker with prebuilt integration templates embedded with business logic, automated mappings, and transformations for common B2B use cases. Now, you can skip custom ERP integration projects with customizable prebuilt EDI-ERP integration templates.
Stay tuned for even more integration patterns that will take your business capabilities to the next level.
Giving you the tools confidence to thrive
With Celigo, you’ll gain not only the tools you need to support automation enterprise-wide, but also the confidence to drive innovation across your teams.
By adopting Celigo as your integration solution, you can integrate any application and automate any process at scale. Now, you can confidently accept new projects, knowing you can tackle anything that’s thrown your way. This knowledge will empower you and your teams to push boundaries, challenge the status quo, and strive for improvements in every aspect of your business.
With Celigo as your integration partner, you can conquer any business challenge and go beyond what you thought was possible. You aren’t just keeping up with your competitors, you’re leading the pack.
Dive deeper into what’s possible with Celigo, sign up for a demo today.
